-11%
Powerbank 20,000mAh
SKU: PB-A1002
24.90 € 27.90 €
Lowest price in the last 30 days: 24.90 €
This product is out of stock.
Out of stock
Delivery: -
Powerbank with a really large capacity
- 20,000 mAh
- Dual USB ports
- Status indicators
Share:
A perfect accessory to have while on the go, when the battery starts to run low in your smartphone, for example, you have the ability to recharge it wherever you are. The power bank is equipped with a 20000 mAh Li-ion polymer battery, which can charge a regular smartphone about 8 times on one charge. Easily connect up to two devices simultaneously through the USB-A ports.
The power bank takes about 12 hours to fully charge with the included micro-USB cable. It is not recommended to charge your devices at the same time as charging the power bank.
• Short circuit protection
• Charging time: 12 hours
• Charge two devices simultaneously
• Li-ion polymer battery 20000 mAh
• USB-A output current: 5 V DC/2 A, 10 W
• LED lights indicate charging status (25%, 50%, 75%, 100%)
• Integrated protection against overcharging, overcurrent, and total discharge
The package includes: Power bank, micro-USB cable, and manual.
Voltage: 5V DC
Max power (W): 10
IP class: IP20
Battery-type: Built-in (non-replaceable)
