BBC Micro:Bit
Micro Bit, or micro:bit as it is often called, is a single-board computer developed by BBC Learning. Every British student receives one of these mini-computers in the seventh grade, and now the general public can also buy the Micro:bit. Interest around the world is high, especially in the education sector. It's not surprising considering the possibilities that a cheap and small single-board computer opens up! The Micro:bit is a versatile and easy-to-use device that can be used for a wide range of projects, from learning to code to building robots and other electronic devices. It's a great way to get started with programming and electronics and explore the many possibilities they offer.
Filter
Filter Reset filter
